Changes between Version 32 and Version 33 of maestro/Downloads
03/05/09 23:57:20 (16 years ago)
ksgeograf
  • maestro/Downloads
    v32 v33
    3939== Preview releases ==
    4040This release may not be functional. It might not be translated completely. It is here to showcase new features or to get feedback on particular issues. Most users do not want to download these files. If you use the installer, you must uninstall a previous version first. If you use the binaries, DO NOT overwrite your current installation, as the next release will not replace your files, and thus not work. Uninstall will even leave the files there.
    41  *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3620.msi Installer r3620]
    42  *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3620.zip Binaries r3620]
     41 *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3691.msi Installer r3691]
     42 *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3691.zip Binaries r3691]
    4343The number indicates what revision of the source code the items were built with. The [http://trac.osgeo.org/mapguide/log/trunk/Tools/Maestro?verbose=on Revision log] explains what changes are contained in the code.
    4444
    45 r3620 has the following fixes and additions to 1.0.9:
     45r3691 has the following fixes and additions to 1.0.9:
    4646 * Enabled editing of permissions on the root node.
    4747 * Fixed a bug with creating a package from the entire site.
    6363 * Fixed a bug where x and y was swapped on previews.
    6464 * Fixed a bug where the z column was not saved on ODBC setup.
     65 * Folders and resources with dots (.) and slashes (/) are now shown correctly.
     66 * Added a resource validator to check items for common errors
    6567
    6668== Previous releases ==
