Changes between Version 33 and Version 34 of maestro/Downloads
03/07/09 04:02:04 (16 years ago)
ksgeograf
  • maestro/Downloads
    v33 v34
    3939== Preview releases ==
    4040This release may not be functional. It might not be translated completely. It is here to showcase new features or to get feedback on particular issues. Most users do not want to download these files. If you use the installer, you must uninstall a previous version first. If you use the binaries, DO NOT overwrite your current installation, as the next release will not replace your files, and thus not work. Uninstall will even leave the files there.
    41  *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3691.msi Installer r3691]
    42  *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3691.zip Binaries r3691]
     41 *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3705.msi Installer r3705]
     42 *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3705.zip Binaries r3705]
    4343The number indicates what revision of the source code the items were built with. The [http://trac.osgeo.org/mapguide/log/trunk/Tools/Maestro?verbose=on Revision log] explains what changes are contained in the code.
    4444
    45 r3691 has the following fixes and additions to 1.0.9:
     45r3705 has the following fixes and additions to 1.0.9:
    4646 * Enabled editing of permissions on the root node.
    4747 * Fixed a bug with creating a package from the entire site.
    6565 * Folders and resources with dots (.) and slashes (/) are now shown correctly.
    6666 * Added a resource validator to check items for common errors
     67 * Fixed a collision with unsaved items, and the validator
    6768
    6869== Previous releases ==
