Changes between Version 34 and Version 35 of maestro/Downloads
03/07/09 07:42:48 (16 years ago)
ksgeograf
  • maestro/Downloads
    v34 v35
    3939== Preview releases ==
    4040This release may not be functional. It might not be translated completely. It is here to showcase new features or to get feedback on particular issues. Most users do not want to download these files. If you use the installer, you must uninstall a previous version first. If you use the binaries, DO NOT overwrite your current installation, as the next release will not replace your files, and thus not work. Uninstall will even leave the files there.
    41  *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3705.msi Installer r3705]
    42  *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3705.zip Binaries r3705]
     41 *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3706.msi Installer r3706]
     42 *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3706.zip Binaries r3706]
    4343The number indicates what revision of the source code the items were built with. The [http://trac.osgeo.org/mapguide/log/trunk/Tools/Maestro?verbose=on Revision log] explains what changes are contained in the code.
    4444
    45 r3705 has the following fixes and additions to 1.0.9:
     45r3706 has the following fixes and additions to 1.0.9:
    4646 * Enabled editing of permissions on the root node.
    4747 * Fixed a bug with creating a package from the entire site.
    6666 * Added a resource validator to check items for common errors
    6767 * Fixed a collision with unsaved items, and the validator
     68 * Validator now has a progres bar, and can run on a folder
    6869
    6970== Previous releases ==
