Changes between Version 36 and Version 37 of maestro/Downloads
- 05/27/09 14:16:20 (16 years ago)
maestro/Downloads
v36 v37 38 38 39 39 == Preview releases == 40 41 '''*** NOTE: The new preview uses a new installer. You are advised to uninstall the previous version before trying this one out!!! ***''' 42 40 43 This release may not be functional. It might not be translated completely. It is here to showcase new features or to get feedback on particular issues. Most users do not want to download these files. If you use the installer, you must uninstall a previous version first. If you use the binaries, DO NOT overwrite your current installation, as the next release will not replace your files, and thus not work. Uninstall will even leave the files there. 41 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3 706.msi Installer r3706]42 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3 706.zip Binaries r3706]44 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3911.msi Installer r3911] 45 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3911.zip Binaries r3911] 43 46 The number indicates what revision of the source code the items were built with. The [http://trac.osgeo.org/mapguide/log/trunk/Tools/Maestro?verbose=on Revision log] explains what changes are contained in the code. 44 47 45 r3706 has the following fixes and additions to 1.0.9: 48 r3911 has the following fixes and additions to 1.0.9: 49 * Support for large repositories. 50 * Refresh tree when renaming. 51 * Fixed a bug in the validator when saving maps with empty legend labels. 52 * Fixed a bug with dots in the folder/resource names. 53 * Improved upload of managed files. 54 * Simplified projection override. 55 * Added reference listing in the properties window. 56 * Fixed numerous issues with MgCooker, and added options to the GUI. 46 57 * Enabled editing of permissions on the root node. 47 58 * Fixed a bug with creating a package from the entire site.
