Changes between Version 41 and Version 42 of maestro/Downloads
- 07/27/09 01:08:06 (16 years ago)
maestro/Downloads
v41 v42 42 42 43 43 This release may not be functional. It might not be translated completely. It is here to showcase new features or to get feedback on particular issues. Most users do not want to download these files. If you use the installer, you must uninstall a previous version first. If you use the binaries, DO NOT overwrite your current installation, as the next release will not replace your files, and thus not work. Uninstall will even leave the files there. 44 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r 3911.msi Installer r3911]45 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r 3911.zip Binaries r3911]44 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4082.msi Installer r4082] 45 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4082.zip Binaries r4082] 46 46 The number indicates what revision of the source code the items were built with. The [http://trac.osgeo.org/mapguide/log/trunk/Tools/Maestro?verbose=on Revision log] explains what changes are contained in the code. 47 47 48 r 3911has the following fixes and additions to 1.0.9:48 r4082 has the following fixes and additions to 1.0.9: 49 49 * Enabled editing of permissions on the root node. 50 50 * Fixed a bug with creating a package from the entire site. … … 77 77 * Added resource reference listing in the properties window. 78 78 * Fixed numerous issues with MgCooker, and added options to the GUI. 79 * Fixed an issue with the MgCooker connection settings (r408 1)80 * Fixed an error when moving a folder into itself (r408 1)81 * Fixed a chrash with the validator (r408 1)82 * Improved the Package Builder and put it in a seperate Dll for non-Maestro usage (r408 1)79 * Fixed an issue with the MgCooker connection settings (r4082) 80 * Fixed an error when moving a folder into itself (r4082) 81 * Fixed a chrash with the validator (r4082) 82 * Improved the Package Builder and put it in a seperate Dll for non-Maestro usage (r4082) 83 83 84 84 == Previous releases ==
