Changes between Version 44 and Version 45 of maestro/Downloads
08/23/09 06:43:25 (15 years ago)
ksgeograf
  • maestro/Downloads
    v44 v45
    4242
    4343This release may not be functional. It might not be translated completely. It is here to showcase new features or to get feedback on particular issues. Most users do not want to download these files. If you use the installer, you must uninstall a previous version first. If you use the binaries, DO NOT overwrite your current installation, as the next release will not replace your files, and thus not work. Uninstall will even leave the files there.
    44  *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4164.msi Installer r4164]
    45  *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4164.zip Binaries r4164]
     44 *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4177.msi Installer r4177]
     45 *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4177.zip Binaries r4177]
    4646The number indicates what revision of the source code the items were built with. The [http://trac.osgeo.org/mapguide/log/trunk/Tools/Maestro?verbose=on Revision log] explains what changes are contained in the code.
    4747
    48 r4164 has the following fixes and additions to 1.0.9:
     48r4177 has the following fixes and additions to 1.0.9:
    4949 * Enabled editing of permissions on the root node.
    5050 * Fixed a bug with creating a package from the entire site.
    8787 * Added a theme generator with color brewer support (r4163)
    8888 * Fixed problems with shortcuts in installer (r4164)
     89 * Improved the theme generator (r4177)
     90 * Updated assembly version to match build revision (r4177)
    8991
    9092== Previous releases ==
