Changes between Version 46 and Version 47 of maestro/Downloads
08/31/09 10:20:48 (15 years ago)
ksgeograf
  • maestro/Downloads
    v46 v47
    4242
    4343This release may not be functional. It might not be translated completely. It is here to showcase new features or to get feedback on particular issues. Most users do not want to download these files. If you use the installer, you must uninstall a previous version first. If you use the binaries, DO NOT overwrite your current installation, as the next release will not replace your files, and thus not work. Uninstall will even leave the files there.
    44  *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4203.msi Installer r4203]
    45  *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4203.zip Binaries r4203]
     44 *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4208.msi Installer r4208]
     45 *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4208.zip Binaries r4208]
    4646The number indicates what revision of the source code the items were built with. The [http://trac.osgeo.org/mapguide/log/trunk/Tools/Maestro?verbose=on Revision log] explains what changes are contained in the code.
    4747
    48 r4203 has the following fixes and additions to 1.0.9:
     48r4208 has the following fixes and additions to 1.0.9:
    4949 * Enabled editing of permissions on the root node.
    5050 * Fixed a bug with creating a package from the entire site.
    9292 * Fixed various issues with the Search component in WebLayouts (r4203)
    9393 * Added option to read column values in the Expression Editor (r4203)
     94 * Fixed a disabled button in the Expression Editor (r4208)
    9495
    9596== Previous releases ==
