Changes between Version 47 and Version 48 of maestro/Downloads
- 11/01/09 13:52:22 (15 years ago)
maestro/Downloads
v47 v48 42 42 43 43 This release may not be functional. It might not be translated completely. It is here to showcase new features or to get feedback on particular issues. Most users do not want to download these files. If you use the installer, you must uninstall a previous version first. If you use the binaries, DO NOT overwrite your current installation, as the next release will not replace your files, and thus not work. Uninstall will even leave the files there. 44 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4 208.msi Installer r4208]45 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4 208.zip Binaries r4208]44 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4326.msi Installer r4326] 45 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4326.zip Binaries r4326] 46 46 The number indicates what revision of the source code the items were built with. The [http://trac.osgeo.org/mapguide/log/trunk/Tools/Maestro?verbose=on Revision log] explains what changes are contained in the code. 47 47 48 r4 208has the following fixes and additions to 1.0.9:48 r4326 has the following fixes and additions to 1.0.9: 49 49 * Enabled editing of permissions on the root node. 50 50 * Fixed a bug with creating a package from the entire site. … … 93 93 * Added option to read column values in the Expression Editor (r4203) 94 94 * Fixed a disabled button in the Expression Editor (r4208) 95 * French translation by Pierre Cardinal (r4326) 95 96 96 97 == Previous releases ==
