Changes between Version 53 and Version 54 of maestro/Downloads
12/24/09 04:17:57 (15 years ago)
ksgeograf
  • maestro/Downloads
    v53 v54
    4242
    4343This release may not be functional. It might not be translated completely. It is here to showcase new features or to get feedback on particular issues. Most users do not want to download these files. If you use the installer, you must uninstall a previous version first. If you use the binaries, DO NOT overwrite your current installation, as the next release will not replace your files, and thus not work. Uninstall will even leave the files there.
    44  *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4437.msi Installer r4437]
    45  *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4437.zip Binaries r4437]
     44 *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4475.msi Installer r4475]
     45 *  [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4475.zip Binaries r4475]
    4646The number indicates what revision of the source code the items were built with. The [http://trac.osgeo.org/mapguide/log/trunk/Tools/Maestro?verbose=on Revision log] explains what changes are contained in the code.
    4747
    48 r4437 has the following fixes and additions to 1.0.9:
     48r4475 has the following fixes and additions to 1.0.9:
    4949 * Enabled editing of permissions on the root node.
    5050 * Fixed a bug with creating a package from the entire site.
    108108 * Fixed a bug wit parsing schemas (WMS had this error, maybe others) (r4431)
    109109 * Improved default templates for layer and SymbolDefinition, thanks to Jason Birch (r4437)
     110 * Many fixes for the translation system (r4475)
     111 * Many minor UI fixes and bugfixes related to build 4358 (r4475)
     112 * Access to the expression editor from various properties in the layer styles (r4475)
     113 * Fixed a bug with MgCooker and partial runs (r4475)
     114 * Fixed a bug with composite linestyles (r4475)
    110115
    111116== Previous releases ==
