43 | | 2.1 Previews coming soon. |
| 43 | This release may not be functional. It might not be translated completely. It is here to showcase new features or to get feedback on particular issues. Most users do not want to download these files. If you use the installer, you must uninstall a previous version first. If you use the binaries, DO NOT overwrite your current installation, as the next release will not replace your files, and thus not work. Uninstall will even leave the files there. |
| 44 | |
| 45 | * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4814.msi Installer r4814] |
| 46 | * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4814.zip Binaries r4814] |
| 47 | |
| 48 | The number indicates what revision of the source code the items were built with. |
| 49 | |
| 50 | The 2.1 Preview release contains the following new enhancements introduced since 2.0: |
| 51 | |
| 52 | * #1312: DSN browsing support for ODBC Editor |
| 53 | * #1311: Open Layer Editor when double clicking a Layer in the Map Editor |
| 54 | * #1321: Add layers to Map Editor by dragging and dropping layer definitions from the Site Explorer |
| 55 | * #1314: Local Feature Source Preview (disabled at the moment due to #708) |
| 56 | * #579: Basic Load Procedure Support |
| 57 | |
| 58 | Special thanks to Crispin from 1Spatial for providing the following enhancements |
| 59 | |
| 60 | * #1328: Enhance Right-Click Resource Tree Menu |
| 61 | * #1327: Add Find and Replace Functionality to XML Editor |
| 62 | * #1326: Apply Overrides to Multiple Coordinate Systems |
| 63 | |
| 64 | For a detailed list of changes, check the [http://trac.osgeo.org/mapguide/log/trunk/Tools/Maestro?action=stop_on_copy&rev=4814&stop_rev=4650&mode=stop_on_copy&verbose=on Revision Log] |
