Changes between Version 65 and Version 66 of maestro/Downloads
06/07/10 01:05:12 (15 years ago)
jng
  • maestro/Downloads
    v65 v66
    4343This release may not be functional. It might not be translated completely. It is here to showcase new features or to get feedback on particular issues. Most users do not want to download these files. If you use the installer, you must uninstall a previous version first. If you use the binaries, DO NOT overwrite your current installation, as the next release will not replace your files, and thus not work. Uninstall will even leave the files there.
    4444
     45=== 2.1 Preview Release 2 ===
     46
     47 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4936.msi Installer r4936]
     48 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4936.zip Binaries r4936]
     49
     50=== 2.1 Preview Release 1 ===
     51
    4552 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4814.msi Installer r4814]
    4653 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4814.zip Binaries r4814]
    4855The number indicates what revision of the source code the items were built with.
    4956
    50 The 2.1 Preview release contains the following new enhancements introduced since 2.0:
     57The 2.1 Preview Release 2 contains an updated french translation provided by Pierre Cardinal, and a small list of fixes added since the 1st 2.1 Preview Release outlined here [http://trac.osgeo.org/mapguide/log/trunk/Tools/Maestro?action=stop_on_copy&rev=4936&stop_rev=4815&mode=stop_on_copy&verbose=on here]
     58
     59The 2.1 Preview Release 1 contains the following new enhancements introduced since 2.0:
    5160
    5261 * #1312: DSN browsing support for ODBC Editor
    6271 * #1326: Apply Overrides to Multiple Coordinate Systems
    6372
    64 For a detailed list of changes, check the [http://trac.osgeo.org/mapguide/log/trunk/Tools/Maestro?action=stop_on_copy&rev=4814&stop_rev=4650&mode=stop_on_copy&verbose=on Revision Log]
     73For a detailed list of changes between 2.0 and the 2.1 Preview Release 1, check the [http://trac.osgeo.org/mapguide/log/trunk/Tools/Maestro?action=stop_on_copy&rev=4814&stop_rev=4650&mode=stop_on_copy&verbose=on Revision Log]
    6574
    6675== Previous releases ==
