Changes between Version 1 and Version 2 of maestro/MaestroAPI/samples/RuntimeMap
08/26/08 01:32:37 (16 years ago)
MaksimS
  • maestro/MaestroAPI/samples/RuntimeMap
    v1 v2
    3636}}}
    3737
    38 Having a reference to RuntimeMap enables us manipulating Library-resident map "clone" (see conn.CreateRuntimeMap) sitting in a Session. Don't forget - each MG Session may have different instance of RuntimeMap in it. When RuntimeMap is created, it's properties (including layers, layer visibility, etc.) is inherited from the original MapDefinition. Let's change visibility of PARCELS layer initially turned off:
     38Having a reference to RuntimeMap enables us manipulating Library-resident map "clone" (see conn.CreateRuntimeMap) sitting in a Session. Don't forget - each MG Session may have different instance of RuntimeMap in it. When RuntimeMap is created, it's properties (including layers, layer visibility, etc.) is inherited from the original MapDefinition. Let's change visibility of PARCELS layer initially being turned off:
    3939
    4040{{{
