Changes between Version 3 and Version 4 of maestro/Sourcecode
- 05/20/08 03:18:35 (17 years ago)
maestro/Sourcecode
v3 v4 23 23 24 24 == Compiling the code == 25 Enter the folder Maestro/Maestro, and double click the file "Update DEBUG environment.bat". This will copy required files into the bin/Debug folder. Then doubleclick the solution file "OSGeo. MapGuide.Maestro.sln". Once loaded, press F5 to run the application in debug mode.25 Enter the folder Maestro/Maestro, and double click the file "Update DEBUG environment.bat". This will copy required files into the bin/Debug folder. Then doubleclick the solution file "OSGeo.!MapGuide.Maestro.sln". Once loaded, press F5 to run the application in debug mode. 26 26 27 27 === Getting code updates ===
