Changes between Version 5 and Version 6 of maestro/Sourcecode
02/06/13 13:29:29 (12 years ago)
davidwilhelmsson
Added "PageOutline"
  • maestro/Sourcecode
    v5 v6
     1[[PageOutline]]
    12
    2 == !MapGuide Maestro Source Code ==
     3= !MapGuide Maestro Source Code =
    34This page contains instructions for downloading and compiling [wiki:maestro MapGuide Maestro].
    45
    2526Enter the folder Maestro/Maestro, and double click the file "Update DEBUG environment.bat". This will copy required files into the bin/Debug folder. Then doubleclick the solution file "OSGeo.!MapGuide.Maestro.sln". Once loaded, press F5 to run the application in debug mode.
    2627
    27 === Getting code updates ===
     28== Getting code updates ==
    2829From time to time, you can check for updates, by right clicking the folder and choosing SVN Update. The TortoiseSVN context menu also gives access to code change history.
    2930
