Changes between Version 2 and Version 3 of maestro/Translation
12/08/09 14:39:02 (15 years ago)
ksgeograf
  • maestro/Translation
    v2 v3
    99  * Microsoft .Net Framework 2.0 [http://www.microsoft.com/downloads/details.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5 Download] (Should be installed)
    1010  * Microsoft .Net 2.0 SDK [http://www.microsoft.com/downloads/details.aspx?FamilyID=fe6f2099-b7b4-4f47-a244-c96d69c35dec Download] (Included in Visual Studio 2005 or newer)
    11   * A Subversion client, TortoiseSVN is fine for Windows [/http://tortoisesvn.net/downloads Download]
     11  * A Subversion client, TortoiseSVN is fine for Windows [http://tortoisesvn.net/downloads Download]
    1212
    1313All the mentioned files should install and run just fine under Wine, except TortoiseSVN.
    130130All the files that are missing a "neutral" resx file (those with only a `*`.en-US.resx file) must be edited with a text editor. They all start with a lot of boilerplate system code, and then multiple entries of the form:
    131131{{{
    132   <data name="TimeParseError" xml:space="preserve">
    133     <value>Unable to parse "{0}" into a time offset: {1}</value>
     132  <data name="OpenFileError" xml:space="preserve">
     133    <value>Unable to open "{0}", error message: {1}</value>
    134134  </data>
    135135}}}
    137137The "name" attribute is a system key, and may not be changed.
    138138The text between the {{{<value>}}} and {{{</value>}}} is the one that needs translating.
    139 The special items {0} and {1} are placeholders for some text that Maestro will insert. It should be fairly obvious what the fields will be substituted with, but if in doubt, ask on the [http://mapguide.osgeo.org/user.html MapGuide-Users mail list].
     139The special items !{0} and !{1} are placeholders for some text that Maestro will insert. It should be fairly obvious what the fields will be substituted with, but if in doubt, ask on the [http://mapguide.osgeo.org/user.html MapGuide-Users mail list].
    140140
    141141== Building and testing the dll's ==
