Changes between Version 4 and Version 5 of GSoC2013Reports
07/29/13 09:12:23 (11 years ago)
steve
  • GSoC2013Reports
    v4 v5
    132132        * When you have the setup.exe run it.
    133133        * Choose the next option: Advance Install > Install from internet > Root Directory > Local package directory > Direct connection
    134         * Choose a restrictive package for example "gdal-mrsid" or " gdal-ecw " or both,  you should to choose these because I just created a files for each
     134        * Choose a restrictive package for example "gdal-mrsid" or " gdal-ecw " or both,  you should to choose these because I just created a file for each
    135135          one in download.osgeo.org server. If you choose another restrictive package setup.exe will raise an error,  and choose another normal package for
    136136          example: "gdal-java".
