Changes between Version 13 and Version 14 of GSoc2013Tests
09/11/13 14:11:31 (11 years ago)
steve
  • GSoc2013Tests
    v13 v14
    1919      The OSGeo4w Setup.exe downloads the [http://download.osgeo.org/osgeo4w/testing_license/setup.ini setup.ini] file with a list of all packages each time when it is run.  This   file should be recreated on the server by running the script invoking `regen.sh` on the web each time packages are uploaded. You need to recreate the `setup.ini` in order to update it with all entries for each non-open source packages, thus:
    2020        {{{
    21            # go to main directory of osgeo4w, there is a script called rengen.sh
     21           # go to main directory of testing version in "/osgeo/download/osgeo4w/testing_license/" directory, there is a script called regen.sh
    2222           ./regen.sh   # it will run perl script genini
    2323
