Changes between Initial Version and Version 1 of InstallerTranslation
02/15/10 01:20:34 (15 years ago)
jmckenna
add initial steps (jeff & hayashi)
  • InstallerTranslation
     1== Steps to Translate OSGeo4W-setup.exe ==
     3 * checkout local copy of setup files from Subversion, for example:
     4   {{{
     5     svn co https://svn.osgeo.org/osgeo4w/trunk/setup/ setup --username yourname
     6   }}}
     7 * copy ''res_en.rc'' and rename extension to your new language, such as:
     8   {{{
     9     res_ja.rc
     10   }}}
     11 * modify line#1 and #2 for your new language
     12   * use appropriate code identifier for your international characters (http://msdn.microsoft.com/en-us/library/dd317756%28VS.85%29.aspx)
     13 * replace English installer text in all CONTROL, CAPTION, LTEXT, RTEXT objects, such as:
     14    {{{
     15      CAPTION "OSGeo4Wセットアップ-インストールタイプの選択"
     16    }}}
     17   * be careful of making sure that the interface accelerators are kept, such as ''"(&D)"'':
     18     {{{
     19          CONTROL         "インストールせずにダウンロード(&D)",
     20     }}}
     21     * (background on menu resource accelerators: http://msdn.microsoft.com/en-us/library/syzb5sda%28VS.80%29.aspx)
     22   * you might have to modify the size/spacing of your new strings in the objects. For example, the values below for "71,120,200,10" mean: x,y,width,height - you might have to change the ''width'' value for longer translated strings
     23
     24     {{{
     25           CONTROL         "ローカルディレクトリからインストール(&L)",IDC_SOURCE_CWD,"Button",
     26                           BS_AUTORADIOBUTTON | WS_TABSTOP,71,120,200,10
     27     }}}
     28
     29 * include your new '''res_[lang].rc''' file at the bottom of the file ''res.rc'' such as:
     30   {{{
     31     #include "res_en.rc"
     32     ...
     33     #include "res_ja.rc"
     34   }}}
     35 * complile your new ''setup.exe'', by following the steps in SetupDevelopment
     36 * test your new translated setup.exe
     37 * commit your changes to Subversion
     38 * inform the mailing list of your new translation
     39   * you might need assistance to publish the live osgeo4w-setup.exe to the download server (inform mailing list)
     40
     41== Documentation Translation ==
     42
     43* to be determined
