Changes between Version 1 and Version 2 of InstallerTranslation
- 02/15/10 01:22:11 (15 years ago)
v1 v2 10 10 }}} 11 11 * modify line#1 and #2 for your new language 12 * use appropriate code identifier for your international characters ( http://msdn.microsoft.com/en-us/library/dd317756%28VS.85%29.aspx)12 * use appropriate code identifier for your international characters ([http://msdn.microsoft.com/en-us/library/dd317756%28VS.85%29.aspx microsoft documentation]) 13 13 * replace English installer text in all CONTROL, CAPTION, LTEXT, RTEXT objects, such as: 14 14 {{{ … … 19 19 CONTROL "インストールせずにダウンロード(&D)", 20 20 }}} 21 * (background on menu resource accelerators: http://msdn.microsoft.com/en-us/library/syzb5sda%28VS.80%29.aspx)21 * (background on menu resource accelerators: [http://msdn.microsoft.com/en-us/library/syzb5sda%28VS.80%29.aspx microsoft documentation]) 22 22 * you might have to modify the size/spacing of your new strings in the objects. For example, the values below for "71,120,200,10" mean: x,y,width,height - you might have to change the ''width'' value for longer translated strings 23 23
