| 1 | [[TOC]] |
| 2 | |
| 3 | = セットアップ開発 = |
| 4 | |
| 5 | == Background == |
| 6 | |
| 7 | The OSGeo4W GUI Installer is derived from the same code that the Cygwin installer uses (Cygwin is a Unix emulator on Windows). More information about this code can be found at: |
| 8 | |
| 9 | http://cygwin.com/setup.html |
| 10 | |
| 11 | == Building your own setup.exe == |
| 12 | |
| 13 | 1. Download Cygwin installer |
| 14 | |
| 15 | http://www.cygwin.com/setup.exe |
| 16 | |
| 17 | 2. Install Cygwin |
| 18 | |
| 19 | * in the installer, no need to change anything (press <Next> until you must choose a download site) |
| 20 | * in the '''Choose a Download Site''' window, highlight a URL that appears close to your country location, and press <Next> |
| 21 | * in the '''Select Packages''' window, make sure to install the following packages (click on "Skip" until you see a version number beside the package name) |
| 22 | * Devel |
| 23 | * autoconf |
| 24 | * automake |
| 25 | * bison |
| 26 | * flex |
| 27 | * gcc-mingw-g++ |
| 28 | * libtool |
| 29 | * make |
| 30 | * Mingw |
| 31 | * mingw-zlib |
| 32 | * mingw-bzip2 |
| 33 | * also install all packages that are dependencies of the above ones (the cygwin installer should have automatically selected them for you) |
| 34 | * after selecting the required packages, press <Next> to begin installing |
| 35 | * you should now have a Cygwin shortcut on your desktop |
| 36 | * if you chose default locations, if you open Windows Explorer you will see that Cygwin exists at ''C:\cygwin'' |
| 37 | |
| 38 | 3. If you don't have Subversion installed yet: |
| 39 | |
| 40 | * download and install a fancy GUI for SVN (such as http://tortoisesvn.tigris.org/), or |
| 41 | * use a commandline SVN client such as from [http://subversion.tigris.org/files/documents/15/45222/svn-win32-1.5.6.zip here] |
| 42 | * copy the contents of that zip into your Program Files directory |
| 43 | * add 'C:\Program Files\svn-win32-1.5.6\bin' to your PATH environment variable |
| 44 | |
| 45 | 4. Checkout a local copy of the OSGeo4W setup code into your Cygwin home directory |
| 46 | |
| 47 | * using SVN commandline: |
| 48 | * double click the "Cygwin" shortcut on your desktop |
| 49 | * execute: |
| 50 | * svn co https://svn.osgeo.org/osgeo4w/trunk/setup setup |
| 51 | * you should now have a "setup" folder in your cygwin home directory, containing the OSGeo4W setup code |
| 52 | * using SVN GUI: |
| 53 | * checkout https://svn.osgeo.org/osgeo4w/trunk/setup to your Cygwin home directory (C:\cygwin\home\jeff) |
| 54 | |
| 55 | 5. Now you are ready to build the OSGeo4W setup.exe |
| 56 | |
| 57 | * double-click the Cygwin desktop shortcut to start Cygwin |
| 58 | * execute the following: |
| 59 | * cd setup |
| 60 | * ./bootstrap.sh |
| 61 | * ./fr_configure |
| 62 | * make |
| 63 | |
| 64 | This should produce a setup.exe executable in the setup directory. |
| 65 | |
| 66 | == Uploading a new setup.exe to the Download Server == |
| 67 | |
| 68 | The fr_upload.sh and package.sh scripts should also be helpful to get the results to the OSGeo4W download server. Note that the executable needs to be updated in two places when new versions are uploaded. One is the http://download.osgeo.org/osgeo4w/osgeo4w-setup.exe binary and the other is the packaged copy in http://download.osgeo.org/osgeo4w/release/setup. |
| 69 | |
| 70 | == エクスプレスパッケージの追加 == |
| 71 | |
| 72 | 以下の手順に沿って新しいエクスプレスインストールパッケージを追加してください: |
| 73 | |
| 74 | * 最後のセクション(IDC_PKG_OPENEV, etc)にあるresource.hの新パッケージのためsymbolic defineを追加します |
| 75 | * res.rc (search for IDC_PKG_OPENEV) に定義されているエクスプレスパッケージダイアログに新しいエントリーを追加します。他のパッケージと位置がかぶらないようにしてください。 |
| 76 | * express_package.cc ファイルにある !PackageControlPair[] 配列に新しいパッケージを追加します。このとき IDC_PKG_ constant とパッケージの名前を一致させてください。 |
| 77 | |
| 78 | [wiki:OSGeo4W_jp 戻る] |
| 79 | |
| 80 | |
