Changes between Initial Version and Version 1 of OSGeo4W_jp/pkg-apt/AptCommands
05/17/10 21:55:45 (15 years ago)
hfujii
  • OSGeo4W_jp/pkg-apt/AptCommands
     1= [wiki:pkg-apt apt] command reference =
     2{{{
     3#!rst
     5   **apt [OPTION]... COMMAND [PACKAGE]...**
     7Commands:
     8---------
     9|     available -  show packages available to be installed
     10|     ball - print tarball name
     11|     build - build package from source in CWD
     12|     download - download package
     13|     find - package containing file
     14|     help - help COMMAND
     15|     install - download and install packages, including dependencies
     16|     list - installed packages
     17|     md5 - check md5 sum
     18|     missing - print missing dependencies
     19|     new - list available upgrades to currently installed packages
     20|     remove - uninstall packages
     21|     requires - print requires: for package
     22|     search - search package list
     23|     setup - cygwin environment
     24|     source - download, build and install
     25|     update - setup.ini
     26|     upgrade - all installed packages
     27|     url - print tarball url
     28|     version - print installed version
     29
     30Options:
     31--------
     32|     -d,--download          : download only
     33|     -i,--ini=FILE          : use setup.ini [D:/o4w/etc/setup//setup.ini]
     34|     -m,--mirror=URL        : use mirror [!http://download.osgeo.org/osgeo4w]
     35|     -r,--root=DIR          : set osgeo4w root [D:/o4w]
     36|     -t,--t=NAME            : set dist name (*curr*, test, prev)
     37|     -x,--no-deps           : ignore dependencies
     38|     -s,--start-menu=NAME   : set the start menu name (OSGeo4W)
     39}}}
     40
     41[wiki:OSGeo4W_jp/pkg-apt 戻る]
