Changes between Version 41 and Version 42 of PackagingInstructions
- 03/15/16 02:58:39 (9 years ago)
v41 v42 71 71 == Post-Install Actions == 72 72 73 Packages may take post-install actions by including a .bat file in the /etc/postinstall directory as part of the package. The filename should be named etc/postinstall/<package>.bat. The bat file will be run with the environment variables OSGEO4W_STARTMENU, OSGEO4W_DESKTOP _LINKS, OSGEO4W_MENU_LINKS, OSGEO4W_HOME, and OSGEO4W_HOME_MSYS defined, and with OSGEO4W_HOME/bin already in the path.73 Packages may take post-install actions by including a .bat file in the /etc/postinstall directory as part of the package. The filename should be named etc/postinstall/<package>.bat. The bat file will be run with the environment variables OSGEO4W_STARTMENU, OSGEO4W_DESKTOP, OSGEO4W_DESKTOP_LINKS, OSGEO4W_MENU_LINKS, OSGEO4W_HOME, and OSGEO4W_HOME_MSYS defined, and with OSGEO4W_HOME/bin already in the path. 74 74 75 75 One very common thing to do in postinstall actions is to insert/update configuration files to include the installed path to the OSGeo4W tree. This is normally done with a postinstall file, and here are 2 examples:: … … 132 132 A Desktop icon: 133 133 {{{ 134 if not %OSGEO4W_DESKTOP_LINKS%==0 xxmklink "% ALLUSERSPROFILE%\Desktop\OpenEV.lnk" "%OSGEO4W_ROOT%\bin\openev.bat"134 if not %OSGEO4W_DESKTOP_LINKS%==0 xxmklink "%OSGEO4W_DESKTOP%\OpenEV.lnk" "%OSGEO4W_ROOT%\bin\openev.bat" 135 135 " " \ "OSGeo4W OpenEV" 1 "%OSGEO4W_ROOT%\apps\openev\icon.ico" 136 136 }}} … … 148 148 if not %OSGEO4W_MENU_LINKS%==0 nircmd shortcut "%O4W_ROOT%\bin\nircmd.exe" "%OSGEO4W_STARTMENU%" "QGIS Browser 1.9.0" "exec hide %O4W_ROOT%\bin\qgis-dev-browser.bat" "%O4W_ROOT%\apps\qgis-dev\icons\QGIS.ico" 149 149 150 if not %OSGEO4W_DESKTOP_LINKS%==0 nircmd shortcut "%O4W_ROOT%\bin\nircmd.exe" "~$folder.desktop$" "QGIS Desktop 1.9.0" "exec hide %O4W_ROOT%\bin\qgis-dev.bat" "%O4W_ROOT%\apps\qgis-dev\icons\QGIS.ico" 151 if not %OSGEO4W_DESKTOP_LINKS%==0 nircmd shortcut "%O4W_ROOT%\bin\nircmd.exe" "~$folder.desktop$" "QGIS Browser 1.9.0" "exec hide %O4W_ROOT%\bin\qgis-dev-browser.bat" "%O4W_ROOT%\apps\qgis-dev\icons\QGIS.ico" 150 if not %OSGEO4W_DESKTOP_LINKS%==0 mkdir "%OSGEO4W_DESKTOP%" 151 if not %OSGEO4W_DESKTOP_LINKS%==0 nircmd shortcut "%O4W_ROOT%\bin\nircmd.exe" "%OSGEO4W_DESKTOP%" "QGIS Desktop 1.9.0" "exec hide %O4W_ROOT%\bin\qgis-dev.bat" "%O4W_ROOT%\apps\qgis-dev\icons\QGIS.ico" 152 if not %OSGEO4W_DESKTOP_LINKS%==0 nircmd shortcut "%O4W_ROOT%\bin\nircmd.exe" "%OSGEO4W_DESKTOP%" "QGIS Browser 1.9.0" "exec hide %O4W_ROOT%\bin\qgis-dev-browser.bat" "%O4W_ROOT%\apps\qgis-dev\icons\QGIS.ico" 152 153 }}} 153 154 … … 158 159 == Pre-Remove Actions == 159 160 160 Packages may also take pre-remove actions by including a .bat file in the /etc/preremove directory as part of the package. The filename should be named etc/preremove/<package>.bat. The bat file will be run with the environment variables OSGEO4W_STARTMENU, OSGEO4W_ HOME and OSGEO4W_HOME_MSYS defined, and with OSGEO4W_HOME/bin already in the path.161 Packages may also take pre-remove actions by including a .bat file in the /etc/preremove directory as part of the package. The filename should be named etc/preremove/<package>.bat. The bat file will be run with the environment variables OSGEO4W_STARTMENU, OSGEO4W_DESKTOP, OSGEO4W_HOME and OSGEO4W_HOME_MSYS defined, and with OSGEO4W_HOME/bin already in the path. 161 162 162 163 A common application for this would be the removal of the shortcuts created in the post install actions.
