Changes between Version 2 and Version 3 of TracImport
04/22/15 15:35:16 (10 years ago)
  • TracImport
    v2 v3
    11= Importing ticket data =
     2[[PageOutline]]
     4To migrate issue tickets from other issue-tracking systems or perform housekeeping actions on tickets or simply synchronize different databases, there are some tools, plug-ins and scripts available, which let you import or update tickets into Trac.
     6== !TicketImportPlugin ==
     8[http://trac-hacks.org/wiki/TicketImportPlugin TicketImportPlugin]: this plug-in lets you import or update into Trac a series of tickets from a '''CSV file''' or (if the [http://pypi.python.org/pypi/xlrd xlrd library] is installed) from an '''Excel spreadsheet'''.
     10== !ExportImportXlsPlugin ==
     12[http://trac-hacks.org/wiki/ExportImportXlsPlugin ExportImportXlsPlugin]: this plug-in adds an admin panel for exporting and importing tickets via '''XLS file'''. Requires the python packages xlwt/rxld.
    213
    314== Bugzilla ==
    415
    5 Ticket data can be imported from Bugzilla using the [http://trac.edgewall.org/browser/trunk/contrib/bugzilla2trac.py bugzilla2trac.py] script, available in the contrib/ directory of the Trac distribution.
     16[http://trac-hacks.org/wiki/BugzillaIssueTrackingPlugin BugzillaIssueTrackingPlugin]: integrates Bugzilla issue data into Trac keeping TracLinks. Ticket data can be imported from Bugzilla using the [trac:browser:trunk/contrib/bugzilla2trac.py bugzilla2trac.py] script, available in the contrib/ directory of the Trac distribution.
    617
    718{{{
    2435
    2536Currently, the following data is imported from Bugzilla:
    2737  * bugs
    2838  * bug activity (field changes)
    3141
    3242The script provides a number of features to ease the conversion, such as:
    34   * PRODUCT_KEYWORDS:  Trac doesn't have the concept of products, so the script provides the ability to attach a ticket keyword instead.
    35
    36   * IGNORE_COMMENTS:  Don't import Bugzilla comments that match a certain regexp.
    37
    38   * STATUS_KEYWORDS:  Attach ticket keywords for the Bugzilla statuses not available in Trac.  By default, the 'VERIFIED' and 'RELEASED' Bugzilla statuses are translated into Trac keywords.
     43  * PRODUCT_KEYWORDS: Trac has no concept of products, so the script provides the ability to attach a ticket keyword instead.
     44  * IGNORE_COMMENTS: Don't import Bugzilla comments that match a certain regexp.
     45  * STATUS_KEYWORDS: Attach ticket keywords for the Bugzilla statuses not available in Trac. By default, the 'VERIFIED' and 'RELEASED' Bugzilla statuses are translated into Trac keywords.
    3946
    4047For more details on the available options, see the configuration section at the top of the script.
    4148
    42 == Sourceforge ==
     49=== Known Issues ===
     50{{{
     51#!comment
     52                   Don't merge this section in the default page
     53}}}
     54[[TicketQuery(keywords=~bugzilla,status=!closed)]]
    4355
    44 Ticket data can be imported from Sourceforge using the [http://trac.edgewall.org/browser/trunk/contrib/sourceforge2trac.py sourceforge2trac.py] script, available in the contrib/ directory of the Trac distribution.
     56The adequate milestone for valid bugzilla2trac issue is usually ''Not applicable'', which means that fixes to the contributed script are not planned for a particular Trac release, but can happen anytime.
     57
     58== Jira ==
     59
     60[http://trac-hacks.org/wiki/JiraToTracIntegration JiraToTracIntegration]: provides tools to import Atlassian Jira backup files into Trac. The plug-in consists of a Python 3.1 commandline tool that:
     61  - Parses the Jira backup XML file.
     62  - Sends the imported Jira data and attachments to Trac using the [http://trac-hacks.org/wiki/XmlRpcPlugin XmlRpcPlugin].
     63  - Generates a htpasswd file containing the imported Jira users and their SHA-512 base64 encoded passwords.
    4564
    4665== Mantis ==
    4766
    48 NB! The mantis2trac script now lives at http://trac-hacks.org/wiki/MantisImportScript . You can always get the latest version from http://trac-hacks.org/changeset/latest/mantisimportscript?old_path=/&filename=mantisimportscript&format=zip
    49
    50 Mantis bugs can be imported using the attached script.
    51
    52 Currently, the following data is imported from Mantis:
     67[http://trac-hacks.org/wiki/MantisImportScript MantisImportScript]: script to import the following data from Mantis into Trac:
    5368  * bugs
    5469  * bug comments
    5570  * bug activity (field changes)
    56   * attachments (as long as the files live in the mantis db, not on the filesystem)
     71  * attachments (as long as the files live in the mantis db, not on the filesystem) .
    5772
    58 If you use the script, please read the NOTES section (at the top of the file) and make sure you adjust the config parameters for your environment.
     73== !PlanetForge ==
    5974
    60 mantis2trac.py has the same parameters as the bugzilla2trac.py script:
    61 {{{
    62 mantis2trac - Imports a bug database from Mantis into Trac.
     75[http://trac-hacks.org/wiki/PlanetForgeImportExportPlugin PlanetForgeImportExportPlugin]: this plugin exports Trac data (wiki, tickets, compoments, permissions, repositories, etc.) using the open format designed by the COCLICO project. It extends the webadmin panel and the 'trac admin ...' command. Has no 'import' feature.
    6376
    64 Usage: mantis2trac.py [options]
     77== Scarab ==
    6578
    66 Available Options:
    67   --db <MySQL dbname>              - Mantis database
    68   --tracenv /path/to/trac/env      - Full path to Trac db environment
    69   -h | --host <MySQL hostname>     - Mantis DNS host name
    70   -u | --user <MySQL username>     - Effective Mantis database user
    71   -p | --passwd <MySQL password>   - Mantis database user password
    72   -c | --clean                     - Remove current Trac tickets before importing
    73   --help | help                    - This help info
     79[http://trac-hacks.org/wiki/ScarabToTracScript ScarabToTracScript]: script that migrates Scarab issues to Trac tickets. Requires [http://trac-hacks.org/wiki/XmlRpcPlugin XmlRpcPlugin]
    7480
    75 Additional configuration options can be defined directly in the script.
    76 }}}
     81== Sourceforge ==
     82
     83[http://trac-hacks.org/wiki/SfnToTracScript SfnToTracScript]: importer of !SourceForge's new backup file (originated from #Trac3521).
     84Also, ticket data can be imported from Sourceforge using the [trac:browser:trunk/contrib/sourceforge2trac.py sourceforge2trac.py] script, available in the contrib/ directory of the Trac distribution.
    7785
    7886== Other ==
    7987
    80 Since trac uses a SQL database to store the data, you can import from other systems by examining the database tables. Just go into [http://www.sqlite.org/sqlite.html sqlite] command line to look at the tables and import into them from your application.
     88Since Trac uses a SQL database to store the data, you can also custom-import from other systems by examining the database tables. Just go into [http://www.sqlite.org/sqlite.html sqlite] command line to look at the tables and import them from your application.
    8189
    82 === Using a comma delimited file - CSV ===
    83 See [http://trac.edgewall.org/attachment/wiki/TracSynchronize/csv2trac.2.py] for details.  This approach is particularly useful if one needs to enter a large number of tickets by hand. (note that the ticket type type field, (task etc...) is also needed for this script to work with more recent Trac releases)
     90=== Comma delimited file - CSV ===
     91See [trac:attachment:csv2trac.2.py:wiki:TracSynchronize csv2trac.2.py] for details. This approach is particularly useful if you need to enter a large number of tickets by hand. Note that the ticket type type field, (task etc...) is also needed for this script to work with more recent Trac releases.
     92Comments on script: The script has an error on line 168: 'Ticket' needs to be 'ticket'. Also, the listed values for severity and priority are swapped.
    8493
     94----
     95See also:
     96 * to import/export wiki pages: TracAdmin,
     97 * to export tickets: TracTickets, TracQuery
