Changes between Version 2 and Version 3 of TracSearch
04/22/15 15:35:16 (10 years ago)
  • TracSearch
    v2 v3
    1 = Using Search =
     1= Using Search
    3 Trac has a built-in search engine to allow finding occurrences of keywords and substrings in wiki pages, tickets and changeset descriptions.
    5 Using the Trac search facility is straightforward and its interface should be familiar to most users.
     3Trac has built-in search functionality to search for occurrences of keywords and substrings in wiki pages, tickets and changeset properties, such as author, revision and log messages.
    64
    75Apart from the [search: Search module], you will also find a small search field above the navigation bar at all time. It provides convenient access to the search module from all pages.
    86
    9 == "Quickjump" searches ==
    10 For quick access to various project resources, the quick-search field at the top of every page can be used to enter a [TracLinks wiki link], which will take you directly to the resource identified by that link.
     7The search results show the most recent modifications ranked first rather than the most relevant result.
    118
    12 For example:
     9== Quick searches
     10For quick access to project resources, the quick-search field at the top of every page can be used to enter a [TracLinks wiki link], which will take you directly to the resource identified by that link:
    1311
    1412 * ![42] -- Opens change set 42
    1513 * !#42 -- Opens ticket number 42
    1614 * !{1} -- Opens report 1
    17  * /trunk -- Opens the browser for the `trunk` directory
     15 * /trunk -- Opens the browser for the `trunk` directory in the default repository
     16 * /repos1/trunk -- Opens the browser for the `trunk` directory in the `repos1` repository
    1817
    19 == Advanced ==
     18== Advanced
    2019
    21 === Disabling Quickjumps ===
    22 To disable the quickjump feature for a search keyword - for example when searching for occurences of the literal word !TracGuide - begin the query with an exclamation mark (!).
     20=== Disabling Quickjump
     21To disable the Quickjump feature for a keyword start the query with an exclamation mark (`!`): use `!TracGuide` to search for occurrences of the literal word !TracGuide.
    2322
    24 === Search Links ===
    25 From the Wiki, it is possible to link to a specific search, using
    26 `search:` links:
     23=== Search Links
     24From the Wiki, it is possible to link to a specific search, using `search:` links:
    2725 * `search:?q=crash` will search for the string "crash"
    28  * `search:?q=trac+link&wiki=on` will search for "trac" and "link"
    29    in wiki pages only
     26 * `search:?q=trac+link&wiki=on` will search for "trac" and "link" in wiki pages only
    3027
    3128----
