Changes between Version 4 and Version 5 of TracSearch
05/08/22 15:12:27 (3 years ago)
  • TracSearch
    v4 v5
    33Trac has built-in search functionality to search for occurrences of keywords and substrings in wiki pages, tickets and changeset properties, such as author, revision and log messages.
    44
    5 Apart from the [search: Search module], you will also find a small search field above the navigation bar at all time. It provides convenient access to the search module from all pages.
     5In addition to the [search: Search module], you will also find a small search field above the navigation bar. It provides convenient access to the search module from all pages.
    66
    7 The search results show the most recent modifications ranked first rather than the most relevant result.
     7The search results show the most recent modifications ranked first.
    88
    99== Quick searches
    1010
    11 For quick access to project resources, the quick-search field at the top of every page can be used to enter a [TracLinks wiki link], which will take you directly to the resource identified by that link:
     11For quick access to project resources, the quick-search field at the top of every page can be used to enter a [TracLinks TracLink], which will take you directly to the resource identified by that link:
    1212
    1313 * ![42] -- Opens change set 42
    2121== Search TracLinks
    2222
    23 From the Wiki, it is possible to link to a specific search, using `search:` links:
    24  * `search:?q=crash` will search for the string "crash"
     23From the Wiki, it is possible to link to a specific search using `search:` links:
    2525 * `search:?q=trac+link&wiki=on` will search for "trac" and "link" in wiki pages only
    2626
    3030
    3131----
    32 See also: TracGuide, TracLinks, TracQuery
     32See also: TracLinks, TracQuery
