Changes between Version 1 and Version 2 of TracSupport
- 06/10/10 13:36:29 (14 years ago)
TracSupport
v1 v2 1 1 = Trac Support = 2 2 3 Like in most [http://www.opensource.org/ open source projects], "free" Trac support is available primarily through the community itself, mainly through the [ http://trac.edgewall.org/wiki/MailingList mailing list] and the project wiki.3 Like in most [http://www.opensource.org/ open source projects], "free" Trac support is available primarily through the community itself, mainly through the [trac:MailingList mailing list] and the project wiki. 4 4 5 There is also an [ http://trac.edgewall.org/wiki/IrcChannel IRC channel], where people might be able to help out. Much of the 'live' development discussions also happen there.5 There is also an [trac:IrcChannel IRC channel], where people might be able to help out. Much of the 'live' development discussions also happen there. 6 6 7 7 Before you start a new support query, make sure you've done the appropriate searching: 8 * in the project's [ http://trac.edgewall.org/wiki/TracFaq FAQ]8 * in the project's [trac:TracFaq FAQ] 9 9 * in past messages to the Trac [http://blog.gmane.org/gmane.comp.version-control.subversion.trac.general?set_user_css=http%3A%2F%2Fwww.edgewall.com%2Fcss%2Fgmane.css&do_set_user_css=t Mailing List] 10 * in the Trac ticket system, using either a [http://trac.edgewall.org/search?q=&ticket=on&wiki=on full search] or a [http://trac.edgewall.org/query?summary=~&keywords=~" ticket query]. 10 * in the Trac ticket system, using either a [http://trac.edgewall.org/search?q=&ticket=on&wiki=on full search] or a [http://trac.edgewall.org/query?summary=~&keywords=~ ticket query]. 11 12 Please '''don't''' create a ticket in this Trac for asking a support question about Trac. Only use it when you face a ''real'' and ''new'' bug in Trac, and do so only after having read the [trac:NewTicketGuidelines NewTicketGuidelines]. The more a bug report or enhancement request complies with those guidelines, the higher the chances are that it will be fixed or implemented promptly! 11 13 12 14 ---- 13 See also: [ http://trac.edgewall.org/wiki/MailingList MailingList], [http://trac.edgewall.org/wiki/CommercialServices CommercialServices]15 See also: [trac:MailingList MailingList], [trac:TracTroubleshooting TracTroubleshooting], [trac:CommercialServices CommercialServices]
