Changes between Version 10 and Version 11 of pkg-apache
02/22/10 00:53:35 (15 years ago)
jmckenna
  • pkg-apache
    v10 v11
    2121
    2222 * Apache is not automatically installed as a service
    23  * to install the Apache service, run the apache-install.bat script from the OSGeo4W commandline.
    24  * The apache-uninstall.bat and apache-restart.bat scripts are also available to uninstall the service, or restart the server.
     23 * to install the Apache service:
     24   * click on the "OSGeo4w" shortcut on your desktop
     25   * the OSGeo4W command window will open
     26   * type the following command:
     27     {{{
     28       apache-install.bat
     29     }}}
     30   * you should see a message such as:
     31     {{{
     32       Installing the Apache OSGeo4W Web Server service
     33       The Apache OSGeo4W Web Server service is successfully installed.
     34       Testing httpd.conf....
     35       Errors reported here must be corrected before the service can be started.
     36       The Apache OSGeo4W Web Server service is starting.
     37       The Apache OSGeo4W Web Server service was started successfully.
     38     }}}
     39 * The ''apache-uninstall.bat'' and ''apache-restart.bat'' scripts are also available to uninstall the service, or restart the server.
    2540
    2641=== Administrative Privileges note ===
