Changes between Initial Version and Version 1 of pkg-apt/AptCommands
02/23/10 00:05:05 (15 years ago)
maphew
initial version
  • pkg-apt/AptCommands
     1{{{
     2#!rst
     3apt command reference
     4=====================
     6   **apt [OPTION]... COMMAND [PACKAGE]...**
     8Commands:
     9---------
     10|     available_ -  show packages available to be installed
     11|     ball_ - print tarball name
     12|     build_ - build package from source in CWD
     13|     download_ - download package
     14|     find_ - package containing file
     15|     help_ - help COMMAND
     16|     install_ - download and install packages, including dependencies
     17|     list_ - installed packages
     18|     md5_ - check md5 sum
     19|     missing_ - print missing dependencies
     20|     new_ - list available upgrades to currently installed packages
     21|     remove_ - uninstall packages
     22|     requires_ - print requires: for package
     23|     search_ - search package list
     24|     setup_ - cygwin environment
     25|     source_ - download, build and install
     26|     update_ - setup.ini
     27|     upgrade_ - all installed packages
     28|     url_ - print tarball url
     29|     version_ - print installed version
     30
     31Options:
     32--------
     33|     -d,--download          download only
     34|     -i,--ini=FILE          use setup.ini [D:/o4w/etc/setup//setup.ini]
     35|     -m,--mirror=URL        use mirror [!http://download.osgeo.org/osgeo4w]
     36|     -r,--root=DIR          set osgeo4w root [D:/o4w]
     37|     -t,--t=NAME            set dist name (*curr*, test, prev)
     38|     -x,--no-deps           ignore dependencies
     39
     40
     41.. _available
     42
     43available - show packages available to be installed
     44
     45.. _ball
     46
     47ball -print tarball name
     48
     49.. _build
     50
     51build -build package from source in CWD
     52
     53.. _download
     54
     55download -download package
     56
     57.. _find
     58
     59find -package containing file
     60
     61.. _help
     62
     63help -help COMMAND
     64
     65.. _install
     66
     67install -download and install packages, including dependencies
     68
     69.. _list
     70
     71list -installed packages
     72
     73.. _md5
     74
     75md5 -check md5 sum
     76
     77.. _missing
     78
     79missing -print missing dependencies
     80
     81.. _new
     82
     83new -list available upgrades to currently installed packages
     84
     85.. _remove
     86
     87remove -uninstall packages
     88
     89.. _requires
     90
     91requires -print requires: for package
     92
     93.. _search
     94
     95search -search package list
     96
     97.. _setup
     98
     99setup -cygwin environment
     100
     101.. _source
     102
     103source -download, build and install
     104
     105.. _update
     106
     107update -setup.ini
     108
     109.. _upgrade
     110
     111upgrade -all installed packages
     112
     113.. _url
     114
     115url -print tarball url
     116
     117.. _version
     118
     119version -print installed version
     120
     121
     122}}}
     123
