Changes between Version 1 and Version 2 of pkg-apt/AptDevelopment
09/06/11 21:05:53 (13 years ago)
maphew
overall goals
  • pkg-apt/AptDevelopment
    v1 v2
    1 ''the ideas and theories which drive apt developmeant and notes on the development environment''
     1''the ideas and theories which drive apt development and notes on the development environment''
     3== Overall Goals ==
     5 * simple command line installation, upgrade and removal of packages
     6 * always compatible with `osgeo4w-setup.exe`. People should never feel like they have to choose one over the other.
    27
    38== Development Environment ==
    4 For better or worse, this is what I use to work on [wiki:pkg-apt].
     9For better or worse, this is what [wiki:MattWilkie I] use to work on [wiki:pkg-apt].
    510
    6 IDE: I'm using this project to learn how to use the [http://webpages.charter.net/edreamleo/front.html Leo Outline Editor]. Bring apt.py into a `@file` node (drag and drop should do nicely) and you should see the functions split out into a tree that's somewhat easier to understand than a big long file. It does that for me anyway.
     11'''IDE''': I'm using this project to learn how to use the [http://webpages.charter.net/edreamleo/front.html Leo Outline Editor]. Bring apt.py into a `@file` node (drag and drop should do nicely) and you should see the functions split out into a tree that's somewhat easier to understand than a big long file. To use Leo with o4w's python `apt install python-win32 pyqt4 sip`.
    712
    8 PYTHON: 2.5, 2.6, 2.7, installed in C:\ and registered with Windows. I used to use solely the python 2.5 within o4w but stopped when Leo started requiring 2.6. I'm now working towards using solely 2.7 from the testing repository (as soon as I get the problem with x64 python registering properly licked). As yet I don't think apt itself requires anything newer than 2.5.
     13'''PYTHON''':  I'm now working towards using solely 2.7 from the [RequiresPython#Testingrepository testing repository] (as soon as I get the problem with x64 python registering properly licked, #114). As yet I don't think apt itself requires anything newer than 2.5.
