Changes between Initial Version and Version 1 of pkg-gdal16
11/28/08 12:07:23 (16 years ago)
warmerdam
  • pkg-gdal16
     1= gdal16 =
     3 * Raster / Vector format geospatial data access library (1.6 ABI)
     4 * This package tracks the 1.6 branch of GDAL/OGR, and will maintain C/C++ ABI compatibility to the 1.6 ABI indefinately.  However, it is not compatible with the 1.5 ABI used by the primary GDAL package.
     5 * Currently all in one package for libraries, commands and docs.
     6 * The gdal-16 package unpacks in ''osgeo4w''\apps\gdal-16 and does not disturb the normal gdal package.  To actually use the gdal-16 package, run the "gdal16.bat" script in the OSGeo4W console window.
     7 * Note that while running the "gdal16.bat" script makes it possible to use the gdal-1.6.x utilities (like gdal_translate) it does '''not''' affect the other GDAL using programs like MapServer, or OpenEV which will continue to use the GDAL from the standard [wiki:pkg-gdal].
     8 * Maintainer is FrankWarmerdam
