Changes between Version 2 and Version 3 of xxmklink
- 05/25/10 11:21:06 (15 years ago)
xxmklink
v2 v3 1 `xxmklink` is a command line program to create Windows menu shortcuts and is used by most Osgeo4w install packages (as part of the base [wiki:pkg-msvcrt]). It's homepage is http://www.xxcopy.com/xxcopy38.htm 1 = xxmklink.exe = 2 2 3 A command line program to create Windows menu shortcuts and is used by most Osgeo4w install packages (as part of the base [wiki:pkg-msvcrt]). It's homepage is http://www.xxcopy.com/xxcopy38.htm 4 5 Typical usage is documented at http://trac.osgeo.org/osgeo4w/wiki/PackagingInstructions#CreatingShortcuts 3 6 4 7 xxmklink is normally free only for personal use, however the author has granted osgeo4w special authorization:
