Changes between Version 2 and Version 3 of InterWiki
04/22/15 15:34:51 (10 years ago)
  • InterWiki
    v2 v3
    1 = Support for InterWiki links =
     1= Support for InterWiki links
    3 ''(since [trac:milestone:0.10 0.10])''
     3== Definition
    44
    5 == Definition ==
     5An InterWiki link can be used for referring to a Wiki page located in another Wiki system, and by extension, to any object located in any other Web application, provided a simple URL mapping can be done.
    66
    7 An InterWiki link can be used for referring to a Wiki page
    8 located in another Wiki system, and by extension, to any object
    9 located in any other Web application, provided a simple URL
    10 mapping can be done.
     7At the extreme, InterWiki prefixes can even be used to simply introduce links to new protocols, such as `tsvn:` used by [trac:TortoiseSvn TortoiseSvn].
    118
    12 At the extreme, InterWiki prefixes can even be used to simply introduce
    13 links to new protocols, such as `tsvn:` used by [trac:TortoiseSvn TortoiseSvn].
    14
    15 == Link Syntax ==
     9== Link Syntax
    1610
    1711{{{
    1913}}}
    2014
    21 The link is composed by the targeted Wiki (or system) name,
    22 followed by a colon (e.g. `MeatBall:`),
    23 followed by a page specification in the target.
     15The link is composed by the targeted Wiki (or system) name, followed by a colon, eg `MeatBall:`, followed by a page specification in the target.
    2416Note that, as for InterTrac prefixes, '''InterWiki prefixes are case insensitive'''.
    2517
    26 The target Wiki URL is looked up in the InterMapTxt wiki page,
    27 modelled after MeatBall:InterMapTxt.
     18The target Wiki URL is looked up in the `[interwiki]` section of TracIni or in the InterMapTxt wiki page, modeled after MeatBall:InterMapTxt. If a prefix is defined in both the `[interwiki]` section and InterMapTxt, the `[interwiki]` section takes precedence.
    2819
    29 In addition to traditional InterWiki links, where the target
    30 is simply ''appended'' to the URL,
    31 Trac supports parametric InterWiki URLs:
    32 identifiers `$1`, `$2`, ... in the URL
    33 will be replaced by corresponding arguments.
    34 The argument list is formed by splitting the page identifier
    35 using the ":" separator.
     20In addition to traditional InterWiki links, where the target is simply ''appended'' to the URL, Trac supports parametric InterWiki URLs:
     21identifiers `$1`, `$2`, ... in the URL will be replaced by corresponding arguments.
     22The argument list is formed by splitting the page identifier using the ":" separator.
    3623
    37 == Examples ==
     24=== [interwiki]
     25
     26Every option in the `[interwiki]` section in TracIni defines one InterWiki prefix. The option name defines the prefix. The option value defines the URL, optionally followed by a description separated from the URL by whitespace. Parametric URLs are supported as well.
     27
     28'''Example:'''
     29{{{
     30[interwiki]
     31MeatBall = http://www.usemod.com/cgi-bin/mb.pl?
     32PEP = http://www.python.org/peps/pep-$1.html Python Enhancement Proposal $1
     33tsvn = tsvn: Interact with TortoiseSvn
     34}}}
     35
     36== Examples
    3837
    3938If the following is an excerpt of the InterMapTxt page:
    6362
    6463Then,
    65  * `MoinMoin:InterWikiMap` should be rendered as MoinMoin:InterWikiMap
    66    and the ''title'' for that link would be "!InterWikiMap in !MoinMoin"
    67  * `Trac-ML:4346` should be rendered as Trac-ML:4346
    68    and the ''title'' for that link would be "Message 4346 in Trac Mailing List"
     64 * `MoinMoin:InterWikiMap` should be rendered as MoinMoin:InterWikiMap and the ''title'' for that link would be "!InterWikiMap in !MoinMoin"
     65 * `Trac-ML:4346` should be rendered as Trac-ML:4346 and the ''title'' for that link would be "Message 4346 in Trac Mailing List"
    6966
    7067----
