Changes between Version 1 and Version 2 of TracIni
06/10/10 13:36:28 (14 years ago)
  • TracIni
    v1 v2
    22[[TracGuideToc]]
    4 Trac configuration is done by editing the '''`trac.ini`''' config file, located in `<projectenv>/conf/trac.ini`.
     4Trac configuration is done by editing the '''`trac.ini`''' config file, located in `<projectenv>/conf/trac.ini`.  Changes to the configuration are usually reflected immediately, though changes to the `[components]` or `[logging]` sections will require restarting the web server. You may also need to restart the web server after creating a global configuration file when none was previously present.
     6The `trac.ini` configuration file should be writable by the web server, as Trac currently relies on the possibility to trigger a complete environment reload to flush its caches.
    57
    68== Global Configuration ==
    79
    8 Since version 0.9, Trac can also read the configuration from a global `trac.ini` file. These global options will then be merged with the environment-specific options, where local options override global options.
     10In versions prior to 0.11, the global configuration was by default located in `$prefix/share/trac/conf/trac.ini` or /etc/trac/trac.ini, depending on the distribution. If you're upgrading, you may want to specify that file to inherit from.  Literally, when you're upgrading to 0.11, you have to add an `[inherit]` section to your project's `trac.ini` file. Additionally, you have to move your customized templates and common images from `$prefix/share/trac/...` to the new location.
    911
    10 The global configuration is by default localted in `$prefix/share/trac/conf/trac.ini`. It can be moved to a different location (for example, `/etc/trac.ini`), but that requires changing the file `trac/siteconfig.py` which gets created when Trac is installed.
     12Global options will be merged with the environment-specific options, where local options override global options. The options file is specified as follows:
     13{{{
     14[inherit]
     15file = /usr/share/trac/conf/trac.ini
     16}}}
     17
     18Note that you can also specify a global option file when creating a new project,  by adding the option `--inherit=/path/to/global/options` to [TracAdmin trac-admin]'s `initenv` command.  If do not do this but nevertheless intend to use a global option file with your new environment, you will have to go through the newly generated conf/trac.ini file and delete the entries that will otherwise override those set in the global file.
     19
    1120
    1221== Reference ==
    1423This is a brief reference of available configuration options.
    1524
    16 [[TracIni]]
     25 ''Note that the [bitten], [spam-filter] and [vote] sections below are added by plugins enabled on this Trac, and therefore won't be part of a default installation.''
    1726
    18 == [components] ==
    19 (''since 0.9'')
     27[[TracIni()]]
    2028
     29
     30== [components] == #components-section
    2131This section is used to enable or disable components provided by plugins, as well as by Trac itself. The component to enable/disable is specified via the name of the option. Whether its enabled is determined by the option value; setting the value to `enabled` or `on` will enable the component, any other value (typically `disabled` or `off`) will disable the component.
    2232
    3646See also: TracPlugins
    3747
    38   ''Note that prior to Trac r2335 (that applies to 0.9b1 and 0.9b2), you would use a `[disabled_components]` section instead. See a [http://projects.edgewall.com/trac/wiki/TracIni?version=42 previous version] of this page for the details.''
     48== [ticket-custom] == #ticket-custom-section
     49
     50In this section, you can define additional fields for tickets. See TracTicketsCustomFields for more details.
     51
     52== [ticket-workflow] == #ticket-workflow-section
     53''(since 0.11)''
     54
     55The workflow for tickets is controlled by plugins.
     56By default, there's only a `ConfigurableTicketWorkflow` component in charge.
     57That component allows the workflow to be configured via this section in the trac.ini file.
     58See TracWorkflow for more details.
     59
     60== [milestone-groups] == #milestone-groups-section
     61''(since 0.11)''
     62
     63As the workflow for tickets is now configurable, there can be many ticket states,
     64and simply displaying closed tickets vs. all the others is maybe not appropriate
     65in all cases. This section enables one to easily create ''groups'' of states
     66that will be shown in different colors in the milestone progress bar.
     67
     68Example configuration (the default only has closed and active):
     69{{{
     70closed = closed
     71# sequence number in the progress bar
     72closed.order = 0
     73# optional extra param for the query (two additional columns: created and modified and sort on created)
     74group=resolution,order=time,col=id,col=summary,col=owner,col=type,col=priority,col=component,col=severity,col=time,col=changetime
     75# indicates groups that count for overall completion
     76closed.overall_completion = truepercentage
     78new = new
     79new.order = 1
     80new.css_class = new
     81new.label = new
     82
     83# one catch-all group is allowed
     84active = *
     85active.order = 2
     86# CSS class for this interval
     87active.css_class = open
     88# Displayed label for this group
     89active.label = in progress
     90}}}
     91
     92The definition consists in a comma-separated list of accepted status.
     93Also, '*' means any status and could be used to associate all remaining
     94states to one catch-all group.
     95
     96The CSS class can be one of: new (yellow), open (no color) or
     97closed (green). New styles can easily be added using the following
     98selector:  `table.progress td.<class>`
     100== [svn:externals] == #svn:externals-section
     101''(since 0.11)''
     102
     103The TracBrowser for Subversion can interpret the `svn:externals` property of folders out of the box.
     104However, if those externals are ''not'' using the `http:` or `https:` protocol, or if a link to a different repository browser such as another Trac or [http://www.viewvc.org/ ViewVC] is desired, then Trac needs to be able to map an external prefix to this other URL.
     105
     106This mapping is done in the `[svn:externals]` section of the TracIni
     107
     108Example:
     109{{{
     110[svn:externals]
     1111 = svn://server/repos1 http://trac/proj1/browser/$path?rev=$rev
     1122 = svn://server/repos2 http://trac/proj2/browser/$path?rev=$rev
     1133 = http://theirserver.org/svn/eng-soft       http://ourserver/viewvc/svn/$path/?pathrev=25914
     1144 = svn://anotherserver.com/tools_repository  http://ourserver/tracs/tools/browser/$path?rev=$rev
     115}}}
     116With the above, the `svn://anotherserver.com/tools_repository/tags/1.1/tools` external will be mapped to `http://ourserver/tracs/tools/browser/tags/1.1/tools?rev=` (and `rev` will be set to the appropriate revision number if the external additionally specifies a revision, see the [http://svnbook.red-bean.com/en/1.4/svn.advanced.externals.html SVN Book on externals] for more details).
     117
     118Note that the number used as a key in the above section is purely used as a place holder, as the URLs themselves can't be used as a key due to various limitations in the configuration file parser.
     119
     120Finally, the relative URLs introduced in [http://subversion.tigris.org/svn_1.5_releasenotes.html#externals Subversion 1.5] are not yet supported.
    39121
    40122----
    41123See also: TracGuide, TracAdmin, TracEnvironment
    42
