Changes between Version 1 and Version 2 of WikiFormatting
- 06/10/10 13:36:28 (14 years ago)
WikiFormatting
v1 v2 81 81 * Item 1 82 82 * Item 1.1 83 * Item 1.1.1 84 * Item 1.1.2 85 * Item 1.1.3 86 * Item 1.2 83 87 * Item 2 84 88 … … 96 100 * Item 1 97 101 * Item 1.1 102 * Item 1.1.1 103 * Item 1.1.2 104 * Item 1.1.3 105 * Item 1.2 98 106 * Item 2 99 107 … … 225 233 * [wiki:ISO9000] 226 234 227 228 === Trac Links === 235 == Trac Links == 229 236 230 237 Wiki pages can link directly to other parts of the Trac system. Pages can refer to tickets, reports, changesets, milestones, source files and other Wiki pages using the following notations: … … 242 249 * ... 243 250 244 See TracLinks for more in-depth information.251 There are many more flavors of Trac links, see TracLinks for more in-depth information. 245 252 246 253 … … 264 271 Urls ending with `.png`, `.gif` or `.jpg` are no longer automatically interpreted as image links, and converted to `<img>` tags. 265 272 266 You now have to use the ![[Image]] macro (see below). 273 You now have to use the ![[Image]] macro. The simplest way to include an image is to upload it as attachment to the current page, and put the filename in a macro call like `[[Image(picture.gif)]]`. 274 275 In addition to the current page, it is possible to refer to other resources: 276 * `[[Image(wiki:WikiFormatting:picture.gif)]]` (referring to attachment on another page) 277 * `[[Image(ticket:1:picture.gif)]]` (file attached to a ticket) 278 * `[[Image(htdocs:picture.gif)]]` (referring to a file inside project htdocs) 279 * `[[Image(source:/trunk/trac/htdocs/trac_logo_mini.png)]]` (a file in repository) 280 281 Example display: [[Image(htdocs:../common/trac_logo_mini.png)]] 282 283 See WikiMacros for further documentation on the `[[Image()]]` macro. 267 284 268 285 … … 273 290 Example: 274 291 {{{ 275 [[ Timestamp]]276 }}} 277 278 Display: 279 [[ Timestamp]]292 [[RecentChanges(Trac,3)]] 293 }}} 294 295 Display: 296 [[RecentChanges(Trac,3)]] 280 297 281 298 See WikiMacros for more information, and a list of installed macros. … … 338 355 339 356 357 == Comments == 358 359 Comments can be added to the plain text. These will not be rendered and will not display in any other format than plain text. 360 {{{ 361 {{{ 362 #!comment 363 Your comment here 364 }}} 365 }}} 366 367 340 368 == Miscellaneous == 341 369 … … 349 377 Display: 350 378 ---- 379 351 380 352 381
