Changes between Version 2 and Version 3 of WikiPageNames
- 04/22/15 15:34:51 (10 years ago)
WikiPageNames
v2 v3 1 = Wiki Page Names =1 = Wiki Page Names 2 2 [[TracGuideToc]] 3 3 4 4 Wiki page names commonly use the CamelCase convention. Within wiki text, any word in CamelCase automatically becomes a hyperlink to the wiki page with that name. 5 5 6 CamelCase page names mustfollow these rules:6 CamelCase page names follow these rules: 7 7 8 1. The name must consist of '''alphabetic characters only''' . No digits, spaces, punctuation,or underscores are allowed.9 2. A name must have at least two capital letters.10 3. The first character must be capitalized.11 4. Every capital letter must be followed by one or more lower-case letters.12 5. The use of slash ( / ) is permitted in page names (possibly representing a hierarchy).8 1. The name must consist of '''alphabetic characters only'''; no digits, spaces, punctuation or underscores are allowed. 9 1. A name must have at least two capital letters. 10 1. The first character must be capitalized. 11 1. Every capital letter must be followed by one or more lower-case letters. 12 1. The use of slash ( / ) is permitted in page names, where it typically represents a hierarchy. 13 13 14 If you want to create a wiki page that does n't follow CamelCase rulesyou can use the following syntax:14 If you want to create a wiki page that does not follow CamelCase rules. you can use the following syntax: 15 15 {{{ 16 * [wiki:Wiki_page], [wiki:ISO9000] 17 * [wiki:"Space Matters"] that page name embeds space characters 18 * or simply: ["WikiPageName"]s (!MoinMoin's internal free links style) 16 * [wiki:Wiki_page], [wiki:ISO9000], 17 and with a label: [wiki:ISO9000 ISO 9000 standard] 18 * [wiki:"Space Matters"] 19 and with a label: [wiki:"Space Matters" all about white space] 20 * or simply: ["WikiPageName"]s 21 * even better, the new [[WikiCreole link style]] 22 and with a label: [[WikiCreole link style|WikiCreole style links]] 19 23 }}} 20 24 21 25 This will be rendered as: 22 * [wiki:Wiki_page], [wiki:ISO9000] 23 * [wiki:"Space Matters"] that page name embeds space characters 24 * or simply: ["WikiPageName"]s (!MoinMoin's internal free links style) 26 * [wiki:Wiki_page], [wiki:ISO9000], 27 and with a label: [wiki:ISO9000 ISO 9000 standard] 28 * [wiki:"Space Matters"] ''(that page name embeds space characters)'' 29 and with a label: [wiki:"Space Matters" all about white space] 30 * or simply: ["WikiPageName"]s 31 * even better, the new [[WikiCreole link style]] 32 and with a label: [[WikiCreole link style|WikiCreole style links]] 25 33 26 Starting with Trac 0.11, it's also possible to link to a specific ''version'' of a Wiki page,as you would do for a specific version of a file, for example: WikiStart@1.34 It is possible to link to a specific ''version'' of a Wiki page as you would do for a specific version of a file, for example: WikiStart@1. 27 35 28 See also TracLinks#QuotingspaceinTracLinks.36 You can also prevent a !CamelCase name from being interpreted as a [TracLinks link] by quoting it with an exclamation mark: `!CamelCase`. See TracLinks#EscapingLinks. 29 37 30 Finally, and as exemplified in the line above, one can also append an anchor to a Wiki page name, in order to link to a specific section within that page. The anchor can easily be seen by hovering the mouse over a section heading, then clicking on the [[html(¶)]] sign that appears at its end. The anchor is usually generated automatically, but it's also possible to specify it explicitly: see WikiFormatting#using-explicit-id-in-heading. 38 As in the example above, you can also append an anchor to a Wiki page name to link to a specific section within that page. The anchor can be seen by hovering the mouse over a section heading, then clicking on the [[html(¶)]] sign that appears at its end. The anchor is usually generated automatically, but it is also possible to specify it explicitly: see WikiFormatting#using-explicit-id-in-heading. 39 31 40 ---- 32 41 See also: WikiNewPage, WikiFormatting, TracWiki, TracLinks
