Changes between Version 1 and Version 2 of WikiRestructuredTextLinks
- 06/10/10 13:36:28 (14 years ago)
v1 v2 1 1 = TracLinks in reStructuredText = 2 2 3 This document illustrates how to use the ` `..trac::`` directive in reStructureThe page is written like3 This document illustrates how to use the `:trac:` role in reStructuredText. The page is written like: 4 4 5 5 {{{ 6 6 {{{ 7 7 #!rst 8 Examples: 8 9 9 Examples:10 10 * Tickets: :trac:`#1` or :trac:`ticket:1` 11 11 * Ticket comments: :trac:`comment:ticket:1:2` … … 21 21 * A particular line of a specific file revision: :trac:`source:/trunk/COPYING@200#L25` 22 22 23 An explicit label can be specified, separated from the link by a space: 24 25 * See :trac:`#1 ticket 1` and the :trac:`source:trunk/COPYING license`. 23 26 }}} 24 27 }}} … … 28 31 {{{ 29 32 #!rst 33 Examples: 30 34 31 Examples:32 35 * Tickets: :trac:`#1` or :trac:`ticket:1` 33 36 * Ticket comments: :trac:`comment:ticket:1:2` … … 43 46 * A particular line of a specific file revision: :trac:`source:/trunk/COPYING@200#L25` 44 47 48 An explicit label can be specified, separated from the link by a space: 49 50 * See :trac:`#1 ticket 1` and the :trac:`source:trunk/COPYING license`. 45 51 }}} 46 52 ---- 47 53 48 Note also that any of the above could have been written using the alternate syntax for roles:54 Note also that any of the above could have been written using substitution references and the `trac::` directive: 49 55 {{{ 50 56 {{{ 51 57 #!rst 58 See |ticket123|. 52 59 53 See `ticket:123`_ 54 55 .. :trac: ticket:123 Ticket 123 60 .. |ticket123| trac:: ticket:123 this ticket 56 61 }}} 57 62 }}} 63 64 This renders as: 58 65 ---- 59 66 60 67 {{{ 61 68 #!rst 69 See |ticket123|. 62 70 63 See _`ticket:123` 64 65 .. trac:: ticket:123 Ticket 123 71 .. |ticket123| trac:: ticket:123 this ticket 66 72 }}} 67 ----68 The above form has the additional benefit of allowing you to specify an explicit label for the link.69 73 70 74 ----
