Changes between Version 10 and Version 11 of spaceship_manual
04/10/18 12:27:55 (7 years ago)
bakaniko
  • spaceship_manual
    v10 v11
    66
    7 Since documentation is built automatically, projects data are stored in project_info.csv file. It is the main point of entry of the docs.
     7Since documentation is built automatically, projects data are stored in `project_info.csv` file. It is the main point of entry of the docs.
    88
    99To add a new project, you have to add a new line in this file. To update a project informations, just modify the corresponding line.
    1212= project_info.csv organization =
    1313
    14 The file is organized with 12 columns/fields separated by the pipe | symbol:
     14The file is organized with 12 columns/fields separated by the pipe `|` symbol:
    1515
    1616{{{
    5353== document? : ==
    5454
    55 Add {{{Y}}} if the project documentation should be build or not {{{reserved to OSGeoLive members}}}
     55Add {{{Y}}} if the project documentation should be build or not `reserved to OSGeoLive members`
    5656
    5757If the project have been retired, please change it to {{{N}}} and move it to retired section.
