Changes between Initial Version and Version 2 of Ticket #2157
12/22/12 12:20:13 (12 years ago)
robe
  • Ticket #2157
    • Property Owner changed from pramsey to robe
  • Ticket #2157 – Description
    initial v2
    22http://www.postgis.org/documentation/manual-svn/ST_DelaunayTriangles.html
    4   The next version I was hoping to incorporate that logic, but that may require I have two versions since some people feel we need to support many versions of GEOS for each instance of PostGIS and I can't therefore require GEOS 3.4.0 without breaking backward compatiblity for some folks who are unfortunate enough to run 2.1 with anything less than GEOS 3.3.
     4  The next version I was hoping to incorporate that logic, but that may require I have two versions since some people feel we need to support many versions of GEOS for each instance of PostGIS and I can't therefore require GEOS 3.4.0 without breaking backward compatiblity for some folks who are unfortunate enough to run 2.1 with anything less than GEOS 3.4.
    66Next iteration, I'm planning to follow the other Sandro's approach as noted here:
