Changes between Initial Version and Version 5 of Ticket #2222
- 04/04/13 11:15:58 (12 years ago)
Ticket #2222
- Property Cc added
- Property Status new → assigned
- Property Summary [raster] WKB format version 1 → [raster] Add ability to change behavior of WKB output for out-db bands
Ticket #2222 – Description
initial v5 1 Version 1 is intended to correct the handling of out-db raster bands. In Version 0, the output of ST_AsBinary() for a band with out-db values returns the path to the out of database raster file, which is generally useless for a client unless the client has access to the database server's file system. 1 ~~Version 1 is intended to correct the handling of out-db raster bands. In Version 0, the output of ST_AsBinary() for a band with out-db values returns the path to the out of database raster file, which is generally useless for a client unless the client has access to the database server's file system.~~ 2 2 3 By using Version 1, we don't break compatibility for those already using Version 0 WKB. 3 ~~By using Version 1, we don't break compatibility for those already using Version 0 WKB.~~ 4 4 5 5 Related ticket regarding ST_AsBinary() is #2217.
