Changes between Version 1 and Version 2 of Ticket #2941
09/27/14 17:56:16 (10 years ago)
robe
  • Ticket #2941 – Description
    v1 v2
    3232
    3333
    34 I thought it was a regression bug, but trying the above on a 2.1.0 install I found lying around yields the same results.  So it seems while the geography type supports non-4326 lon lat spatial reference systems,  you can't insert these into a geography table.
     34I thought it was a regression bug, but trying the above on a 2.1.0 install I found lying around yields the same results.  So it seems while the geography type supports non-4326 lon lat spatial reference systems,  you can't insert these into a typmoded geography table and the only way you can get a geography table with no srid (srid of 0) is to to a bulk insert.
