Changes between Initial Version and Version 1 of Ticket #3384
- 11/30/15 11:08:43 (9 years ago)
Ticket #3384 – Description
initial v1 5 5 Couple of things need changing, some for 2.2 as well 6 6 7 1) our header in docs says if compiling with less than 9.1 (that header should be changed to compiling without raster support) since now it's only relevant if you are compiling with raster support.7 1) our header in docs says if compiling with less than 9.1 (that header should be changed to compiling without raster support) since now it's only relevant if you are compiling without raster support or you for whatever reason want to use scripts. 8 8 9 9 http://postgis.net/docs/manual-2.2/postgis_installation.html#create_new_db
