Changes between Initial Version and Version 3 of Ticket #4047
03/15/18 22:03:03 (7 years ago)
robe
  • Ticket #4047
    • Property Component postgisdocumentation
    • Property Owner changed from pramsey to robe
  • Ticket #4047 – Description
    initial v3
    44{{{
    55https://debbie.postgis.net/job/PostGIS_Make_Dist/label=debbie/183/consoleFull
     705:37:19 generating ../images/st_subdivide01.png
     805:37:19 Could not find style named Style01
     905:37:21 generating ../images/st_subdivide02.png
     1005:37:23 make[1]: *** [Makefile:178: ../images/st_subdivide02.png] Error 1
     1105:37:23 make[1]: Leaving directory '/var/lib/jenkins/workspace/PostGIS_Make_Dist/label/debbie/20b95b81feb9f7e80dc829cd53f2640db4d2933e/doc/html/image_src'
     1205:37:23 make: *** [Makefile:311: images] Error 2
     1305:37:23 /usr/bin/xsltproc --novalid ./xsl/postgis_aggs_mm.xml.xsl postgis-out.xml > postgis_aggs_mm.xml
     1405:37:23 if test x"dbtoepub" = x; then \
     1505:37:23    echo "Error: dbtoepub not found, can't build epub"; \
     1605:37:23    echo "       try installing dbtoepub"; \
     1705:37:25    false; \
     1805:37:25 else \
     1905:37:25        dbtoepub -c "/var/lib/jenkins/workspace/PostGIS_Make_Dist/label/debbie/20b95b81feb9f7e80dc829cd53f2640db4d2933e/doc/html/style.css" \
     2005:37:25         -o postgis-2.5.0dev.epub \
     2105:37:25          postgis-out.xml; \
     2205:37:25 fi
    623}}}
    724
