| 6 | |
| 7 | |
| 8 | {{{ |
| 9 | /var/lib/jenkins/workspace/postgis/branches/3.0/regress/00-regress-install/share/contrib/postgis/rtpostgis_proc_set_search_path.sql |
| 10 | PostgreSQL 10.5 on x86_64-pc-linux-gnu, compiled by gcc (Debian 8.2.0-5) 8.2.0, 64-bit |
| 11 | Postgis 3.0.0dev - r16729 - 2018-09-11 06:20:39 |
| 12 | scripts 3.0.0dev r16729 |
| 13 | raster scripts 3.0.0dev r16729 |
| 14 | GEOS: 3.7.0rc1-CAPI-1.11.0 49f66217 |
| 15 | PROJ: Rel. 5.1.0, June 1st, 2018 |
| 16 | GDAL: GDAL 2.3.1, released 2018/06/22 |
| 17 | |
| 18 | Running tests |
| 19 | |
| 20 | check_gdal .. ok |
| 21 | load_outdb ... ok |
| 22 | check_raster_columns .. ok |
| 23 | check_raster_overviews .. ok |
| 24 | rt_io .. ok |
| 25 | rt_bytea .. ok |
| 26 | rt_wkb .. ok |
| 27 | box3d .. ok |
| 28 | rt_addband .. ok |
| 29 | rt_band .. failed (diff expected obtained: /var/lib/jenkins/workspace/postgis/tmp/3_0_pg10w64/test_10_diff) |
| 30 | ----------------------------------------------------------------------------- |
| 31 | --- rt_band_expected 2018-09-11 06:20:16.310293357 +0000 |
| 32 | +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg10w64/test_10_out 2018-09-11 06:25:52.143617183 +0000 |
| 33 | @@ -12,18 +12,7 @@ |
| 34 | 9876.54321 |
| 35 | 987.654321 |
| 36 | 1234.5678 |
| 37 | -1234.5678 |
| 38 | -1234.5678 |
| 39 | -1234.5678 |
| 40 | -4 |
| 41 | -3 |
| 42 | -2 |
| 43 | -1 |
| 44 | -1 |
| 45 | -1 |
| 46 | -NOTICE: Invalid band index (must use 1-based). Returning original raster |
| 47 | -3 |
| 48 | -NOTICE: Invalid band index (must use 1-based). Returning original raster |
| 49 | |
| 50 | -6|(1,{{7}}) |
| 51 | |
| 52 | +psql: FATAL: the database system is in recovery mode |
| 53 | ----------------------------------------------------------------------------- |
| 54 | rt_valuepercent .. failed (diff expected obtained: /var/lib/jenkins/workspace/postgis/tmp/3_0_pg10w64/test_37_diff) |
| 55 | ----------------------------------------------------------------------------- |
| 56 | --- rt_valuepercent_expected 2018-09-11 06:20:16.906295708 +0000 |
| 57 | +++ /var/lib/jenkins/workspace/postgis/tmp/3_0_pg10w64/test_37_out 2018-09-11 06:25:52.435618333 +0000 |
| 58 | @@ -1,35 +1 @@ |
| 59 | --10.000|0.500 |
| 60 | -3.142|0.500 |
| 61 | --10.000|0.500 |
| 62 | -3.142|0.500 |
| 63 | --10.000|0.010 |
| 64 | -0.000|0.980 |
| 65 | -3.142|0.010 |
| 66 | --10.000|0.500 |
| 67 | -3.100|0.500 |
| 68 | -3.100|0.500 |
| 69 | --10.000|0.500 |
| 70 | --10.000|0.500 |
| 71 | --10.000|0.500 |
| 72 | -3.000|0.000 |
| 73 | -0.500 |
| 74 | -0.010 |
| 75 | -0.500 |
| 76 | -0.500 |
| 77 | -0.500 |
| 78 | -0.500 |
| 79 | -BEGIN |
| 80 | --10.000|0.010 |
| 81 | -0.000|0.980 |
| 82 | -3.142|0.010 |
| 83 | --10.000|0.500 |
| 84 | -1.000|0.000 |
| 85 | --10.000|0.500 |
| 86 | -3.100|0.500 |
| 87 | --1.000|0.000 |
| 88 | -3.100|0.500 |
| 89 | -0.500 |
| 90 | -0.000 |
| 91 | -0.500 |
| 92 | -0.000 |
| 93 | -COMMIT |
| 94 | +psql: FATAL: the database system is in recovery mode |
| 95 | ----------------------------------------------------------------------------- |
| 96 | rt_bandmetadata .. failed (diff expected obtained: /var/lib/jenkins/workspace/postgis/tmp/3_0_pg10w64/test_38_diff) |
| 97 | }}} |
