Changes between Initial Version and Version 1 of Ticket #4245
- 11/19/18 20:30:17 (6 years ago)
Ticket #4245
- Property Summary Debbie failing on all runs of postgis 3.0 → Debbie tickets regress on geography intersects failing on all PostgreSQL branches for postgis 3.0
Ticket #4245 – Description
initial v1 1 1 Even after the postgrsql 12 fix, debbie is still failing. But it seems this change is affecting all postgres branches, not just the 12. The 12 install issues were fixed. 2 3 The test triggering the difference is 4 5 {{{ 6 SELECT '#723', 7 encode(ST_AsEWKB(ST_SnapToGrid( ST_Intersection(a.geog, b.geog)::geometry, 0.00001),'ndr'),'hex') 8 FROM (VALUES (ST_GeogFromText('SRID=4326;POINT(-11.1111111 40)') ), (ST_GeogFromText('SRID=4326;POINT(-11.1111111 55)') ) ) As a(geog) CROSS JOIN ( VALUES (ST_GeogFromText('SRID=4326;POINT(-11.1111111 40)') ), (ST_GeogFromText('SRID=4326;POINT(-11.1111111 55)') )) As b(geog); 9 }}} 10 2 11 3 12
