Changes between Version 1 and Version 7 of Ticket #5547
- 12/04/23 09:33:11 (14 months ago)
Ticket #5547
- Property Milestone PostGIS 3.4.1 → PostGIS 3.3.6
Ticket #5547 – Description
v1 v7 1 this uses a gist index on wkb_geometry when I pass a string, gist (wkb_geometry) 2 3 SELECT fld_zone FROM s_fld_haz_ar WHERE 4 st_intersects(st_geomfromtext('POINT(-83.113523 40.014991)', 4269), wkb_geometry) 5 1 This uses a gist index on wkb_geometry when I pass a string, gist (wkb_geometry) 2 {{{ 3 SELECT fld_zone 4 FROM s_fld_haz_ar 5 WHERE st_intersects( 6 st_geomfromtext('POINT(-83.113523 40.014991)', 4269), 7 wkb_geometry) 8 }}} 6 9 7 10 concatenating text fields to make the same string for the point, it will not use the gist index 8 9 SELECT fld_zone FROM s_fld_haz_ar WHERE st_intersects(st_geomfromtext(concat('POINT(', '-83.113523', ' ', '40.014991', ')'), 4269), wkb_geometry) 10 11 {{{ 12 SELECT fld_zone 13 FROM s_fld_haz_ar 14 WHERE st_intersects( 15 st_geomfromtext( 16 concat('POINT(', '-83.113523', ' ', '40.014991', ')'), 17 4269), 18 wkb_geometry) 19 }}} 11 20 12 21 I'm using POSTGIS="3.4.0 3.4.0", i just upgraded … … 17 26 18 27 I work around it by creating and passing a text variable 19 28 {{{ 20 29 DECLARE p text = concat('POINT(', lon,' ', lat,')'); 21 30 st_intersects(st_geomfromtext(p, 4269), wkb_geometry) 22 31 }}}
