Changes between Initial Version and Version 1 of DevWikiDocNewFeature
07/21/09 04:47:32 (16 years ago)
robe
  • DevWikiDocNewFeature
     1If you are submitting a patch for a new feature, keep in mind we only allow new feature patches for semi-major and major releases, not for minor releases.  So for example if the latest stable version of PostGIS is 1.4 or 1.4 is in freeze mode (which usually happens about 2 months or more before planned release), then your new feature must
     2go into 1.5.
     4For new features, we expect documentation as part of the submission.  To document a new function, please do the following:
     5  1. Make a copy of  template.xml located in trunk/doc of the PostGIS subversion repository ([https://svn.osgeo.org/postgis/trunk/doc])
     6  2. Fill in respective information for your new function and make sure to remove anything that is not relevant.
     7     a. If its not MM compliant please remove that section, but if it is please note the MM section.
     8     b. If it doesn't support curves, 3D etc., please remove that too.
     10  3.  Make very sure in the Availability part to note the PostGIS version this is slated for and if it relies on GEOS, the minimum GEOS version required.
     12  4.  Name your xml file accordingly e.g. MySuperFunc.xml.
     13  5.  Submit this as part of your new function patch.
