Changes between Version 11 and Version 12 of DevWikiDocNewFeature
08/28/09 05:17:31 (15 years ago)
robe
  • DevWikiDocNewFeature
    v11 v12
    2121= Using the WKT image magick image generator to build images! =
    2222
    23 As of PostGIS 1.4 documentation we have an image autogenerator -- thanks to Kevin.  To use
    24 it to generate images for your examples, do the following
     23As of PostGIS 1.4 documentation we have an image autogenerator -- thanks to Kevin Neufeld.  To use
     24it to generate images for your examples, do the following:
    2525
    26261. Define queries using your new function or if you want to provide images for existing then do that and be carefull to make sure the generated geometries fit in a 200x200 grid.
