Changes between Version 19 and Version 20 of DevWikiDocNewFeature
08/28/09 05:26:53 (15 years ago)
robe
  • DevWikiDocNewFeature
    v19 v20
    2424it to generate images for your examples, do the following:
    2525
    26 1. Define queries using your new function or if you want to provide images for existing then do that and be careful to make sure the generated geometries fit in a 200x200 grid otherwise they will be cropped.
     261. Define queries using your new function or if you want to provide images for existing then do that and be careful to make sure the generated geometries fit in a 200x200 grid otherwise they will be cropped.  Try to take up as much of the 200x200 realestate you can.
    2727
    28282. For your query do an ST_AsText to generate the WKT output of it and save this in the image_src folder on
