Changes between Version 22 and Version 23 of DevWikiDocNewFeature
01/19/11 11:43:55 (14 years ago)
robe
  • DevWikiDocNewFeature
    v22 v23
    1313  3.  Make very sure in the Availability part to note the PostGIS version this is slated for and if it relies on GEOS, the minimum GEOS version required.  This is important so that it gets properly highlighted as new in the documentation and people know which version of GEOS they need to be running to have access to this function.
    1414  4. The refpurpose description is kind of important.  You want it to be short but very meaningful. This is the description that shows on the index pages and also
    15 gets added to postgis_comments.sql -- which is what people looking at PgAdminIII or help in psql see.
     15gets added to (depending on component it is part of) : postgis_comments.sql,topology_comments, raster_comments.sql -- which is what people looking at PgAdminIII or help in psql see.
    1616
    1717  5.  Name your xml file accordingly e.g. mysuperfunc.xml.
