Changes between Version 5 and Version 6 of DevWikiDocNewFeature
07/21/09 04:51:44 (16 years ago)
robe
  • DevWikiDocNewFeature
    v5 v6
    1111     b. If it doesn't support curves, 3D etc., please remove that too.
    1212
    13   3.  Make very sure in the Availability part to note the PostGIS version this is slated for and if it relies on GEOS, the minimum GEOS version required.  This is important so that it gets properly highlighted as new in the documentation and people know if they will get it or not.
     13  3.  Make very sure in the Availability part to note the PostGIS version this is slated for and if it relies on GEOS, the minimum GEOS version required.  This is important so that it gets properly highlighted as new in the documentation and people know which version of GEOS they need to be running to have access to this function.
    1414
    1515  4.  Name your xml file accordingly e.g. mysuperfunc.xml.
